RE: Replacing piston ring?
Rings do not only have to seat against the cylinder wall, they also have to seat into the ring groove of the piston. Sometimes this is where the most loss in compression is seen. This is where a new piston is required where the ring groove in the piston is past it's service life. It will show up as broken or cracked rings after a new replacement of the ring.
