RCU Forums - View Single Post - converted Stihl engine - how the heck do I start it!??
Old 05-21-2007 | 08:13 PM
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: converted Stihl engine - how the heck do I start it!??
Where is your Tech support for the engine?
1) picture #6 the bottom fitting on the carb is the pulse line.
There should be a fitting on the engine crankcase it hooks to.
It makes the carb. pump fuel.
2) Your Dad is right. A kill switch grounds out the mag.
3) the carb is probally close enough to start and run.
Put some fuel in the throat flip it over.
4) I believe the needle closest to the engine is the High needle.
There should be a H and a L next to them.
Do you have or can you borrow an electric starter?
Some mags don't put out a lot of spark at slow speede and even less at flip speeds.
I have a Sullivan that is capable of 24 volts and it does a nice job on most stuff.
Pull the plug and check for spark. Flip it a few times.
Then hook any starter to it with the plug out and check for spark.
Let us know what you find.
Who converted this engine?
