RE: Echo BME twin
I have a couple reeds lined up, but the deal is far from done.
I should find out this week sometime. If I come up with some extras I'll give you a heads up.
The solder idea sounds pretty good. We used clay to see if the valves were close to hitting the piston.
But there are no valves to worry about here.
I noticed you have 2 different prop hubs for your twin, which do you like best?
I'm having the one with set screws made. But it's not to late to change if I do it soon.
