RCKen wrote:
I started using Elmer's Carpenter's Glue and haven't looked back once since the switch. Not only is it easier to work with I feel that the quality of my builds have improved since I switched. The biggest "benefit" that most people who promote CA use is that it's faster to build with, but I disagree. It's been my experience that if you plan your build you can build just as quickly with Elmer's as you can with CA..... if you want to. But then again, building fast leads to mistakes...
Ken, I couldn't agree more. When you plan your build for alaphatic resins, not only do things go quicker, but tighter- and square.
I also use Titebond II. There are some things I still use ca for, but VERY few things.
