RCU Forums - View Single Post - OS Max .40 fp
Old 05-22-2007 | 09:13 AM
Bax
Default RE: OS Max .40 fp
When you try to throttle-down with a pressurized fuel tank, the pressure in the tank takes a while to come down, so the engine gets too much fuel. This can cause erratic running, or even quitting, due to too much fuel. A pressurized fuel tank is good only for full-throttle operation unless you have a regulator in the fuel line going to the carburetor fuel inlet.
