RCU Forums - View Single Post - I hate CA Glue
Old 05-22-2007 | 11:54 AM
glover1482's Avatar
glover1482
Default RE: I hate CA Glue
I too am highly alergic to regular CA glues. But the odorless CA is acceptable. Based upon my research, lungs damaged from CA will not fully recover. Use a good mask!
Also be carefull with epoxy, as you can develop alergies to it. Many folks have had to leave the boat building business due to epoxy alergy.
Also whenever sanding aything, use a good mask and not one of the cheap paper ones. It's like knowing whether on not a motorcycle helmet is needed... hit youself in the head with an iron pipe once with helmet on and once with it off; if not convienced helmet is needed, repeat the test.
Fly safe, Glover
