RE: Warbird Servo Selection Help!
You should be able to run standard servos on everything except the rudder which would require something like Hitec 645 or equiv. You could run smaller servos on the throttle and air valve but not really worth the added expense. A good standard servo is the Hitec 425. You will need around a 1200 miliamp battery pack as a minimum for that setup.
