RE: Echo BME twin
Yeah, in those photos, it just had the normal prop bolt. But I later made a hub that uses a stud all the way through, and as you noticed, the set screws. The prop just fits onto the stud with a nut. Later I will use a hub nut if I don't use a spinner....
AV8TOR
