ORIGINAL: BobH
Rick thanks. We have a break at work so I can cut my own gear and bend them. I'd appreciate the spacing between your wheels when you get a chance to measure them ok? Thanks again.
The measured distance between the axle holes is 13.25", measured inside edge to inside edge. The aluminum stock they were made from is 3/16" 6061 stock. All other dimensions are identical to the provided gear, with the exception of having it made 1/2" shorter, to allow for taller 5" wheels. For anyone wanting a custom made gear, TNT Landing Gear has a PDF form on their website for custom ordering gear. I filled in the needed dimensions and faxed it to them.
Rick
