RCU Forums - View Single Post - 2-56 Pull-Pull Solder Problem
Old 02-28-2003 | 05:55 PM
Stick Jammer
Default 2-56 Pull-Pull Solder Problem
You'll need an acid flux to solder steel, rosin won't work. Lightly sand the spring (or rod) with 220 grit and clean with alcohol. A 200+ watt iron works best for me.
