RCU Forums - View Single Post - engine spuder
Old 05-23-2007 | 03:27 PM
red head
Default RE: engine spuder
Take the needle valve out and pump fuel through the carb ( just a little ) clean the needle off and put it back in. Turn it all the way in ( DON"T jam it ) then turn it out 1 1/2 turns and start it up. Once started adjust it. You will probably have to lean it from that point. I adjust mine at 1/2 throttle till I get Max RPM then I richen it about 2 or 3 clicks and check the throttle response and adjust more if needed.
If you still have problems you may want to flush your whole system and check all your tubing. Chances are the above will help.
ENJOY !!! RED
