ORIGINAL: jetpack
Hi LilDiesel,
Would you happen to know what the triangular spacer is behind the crankcase? Is that a mount or some type of tank extender? Maybe it was to capture a wire landing gear set?
The triangular spacer appears to be part of the tank assembly since the tubing from the needle valve connects to and a vent tube is visible on it.
