RE: Lanier Ripper info
Outstanding! I believe that Kirk meant the small prop as a break in prop, right? It might be a little small for flying. With it broken in on the small prop, you should be able to get the minimum 17,500 quite easily on a combat prop. I happen to sell 8 X 3's by the dozen if you need some....
Regards,
Mike
