RCU Forums - View Single Post - Monocoat Hindges Safe?
Old 05-24-2007 | 04:53 AM
Dr1Driver
Default RE: Monocoat Hindges Safe?
Do not use Monokote hinges on a plane that size. They are only suitable for a 1/2A model.
CA hinges are safe if properly installed. I've used them for years and had one in-flight failure on the elevator of my 1/4 Fokker Dr.1.. I feel this failure was brought on by several hard sideways hits the elevator took while transporting. I would, and will, use them again. Pinned hinges are also good, and I prefer Robarts there.
CA Hinge Installation
There are several rules to follow for an easy, correct CA hinge installation. These rules are good for hinges from different manufacturers, including Great Planes and Radio South. I’ve used them on many planes from pylon racers to Unlimited class Fun Fly planes to even a giant scale Stinger (the 1/4 scale size hinges).
Here we go:
Use a #11 blade to cut the slots.
Cut only once per side/per hinge.
Use only thin CA.
Do not double the hinges.
Do not use “kicker”.
Install after covering.
1. Slot the wood pieces (using the #11 blade), install the hinges, and mount the control surface. Gently push the pieces together.
2. Flex the control surface both ways for the maximum amount of travel you expect to use. This will automatically create the proper hinge line gap.
3. Slowly drop 2-3 drops of CA on each hinge at the hinge line on one side only. If any CA puddles in the hinge line, blot it with a paper towel.
4. When that is dry, apply 2-3 drops of CA to the other side of each hinge.
5. When both sides are dry, flex the control surface both ways.
That’s it! The wood will pull out before the hinge will let go. The surface will tend to stay centered and will not flop around. This will help prevent flutter.
Dr.1
