RE: How do you repalce the tail support???
The original tail support rod is glued in. If it broke off right at the base then you'll have to drill it out with a dremel or very carefully with a small bit on a drill. If there is exposed rod that you can grip with pliers you can try applying a CA glue solvent and then twist it free.
