RCU Forums - View Single Post - How do you repalce the tail support???
Old 05-24-2007 | 12:44 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: How do you repalce the tail support???
Acetone will work also........ put some on a q tip and hold the tail upside down and lightly swab a little at the joint. wipe any excess off the surrounding plastic........... also you can try using heat.....a hair dryer usually works ok for loosening up things. then like xeos posted....twist it out gently.
__________________________________________________ ________________________________________________
Of all the things I ever lost.............................................. ...... I miss my mind the most!
