RE: Thunder Tiger GP 61 help!!!
Hey guys, I need some help with the same engine. I just read this post before lunch and during lunch I went and picked up a gallon, of 5% nitro with 11% syn and 11% castor. Should this fuel be sufficient? Also, I need an idea of where to start with the high speed needle, I was going to start out at 2.5 turns an d work from there, but if anyone has a better place to start out at then that would be great.
I kind of inherited the engine along with the Senior Telemaster that it was mounted in so I do not know the history on it, but I do not believe that it has been run much. It had a 13-6 MA prop on it but at the recommendation of the LHS I bought a 12-6. Any other suggestions? Thanks.
