RCU Forums - View Single Post - Beryll Flight Reports?
Old 05-24-2007 | 03:57 PM
  #118
mikedsilva
Default RE: Beryll Flight Reports?
i just received my Beryll here in Aus. It is the older colour scheme and came with the anhedral stabs as well as the normal "flat" stabs. The only problem is, the anhedral stabs are not painted or covered at all! they are simply foam cores, balsa sheeted... they have the joining rods installed but thats it. Any one else had the same experience?
also, the top of my canopy is slightly cracked... the packing is spot on so it must have happened before shipping...
I am planning an AXI outrunner for this one. The mounts supplied are a plastic and not carbon fibre like i have seen in some of the previous posts... where did you get the carbon fibre mounting rings?
mike
