RCU Forums - View Single Post - Where is my CG now?
Old 05-24-2007 | 05:46 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Where is my CG now?
Just to clarify what aerowoof has said. Your CG location needs to be the same as it was prior to the modification. Moving your gear certainly can change your CG and it should be checked prior to flying. Also if you did not already figure it out the main gear now needs to be in front of that CG to avoid nose overs. Putting the wheels in-line with the wings leading edge seems to be a good place for most.
