RE: want to loss 17 oz?? diffferent e-pattern approach
Steve, thanks so much for the info, i believe you and i will be chatting a lot on here in the next few weeks...
Here is my challenge err, question. The Dualsky speed control i am using self sets itself. I leave it at idle on the transmitter, then I turn everything on, then arm the motor.
The speed controller self initializes setting high and low points. If the transmitter is already preprogrammed to limit the ATV, to say 60%.. will it truely be limited or just lower the point at which i reach TRUE full power(max amps etc)?
Thanks for the help...
Don, have you tried the Dualsky HV controllers yet?
Chuck Hochhalter
