RCU Forums - View Single Post - I need help on a scratch wing I'm doing
Old 05-25-2007 | 02:57 AM
Boomerang1's Avatar
Boomerang1
Default RE: I need help on a scratch wing I'm doing
Recess the plate further into the wing, you are out at the end of the spars anyway. While you are at it make the plate just a little bit wider & try to pick up the leading edge as well. Once you are happy with the placement build it back up to the level of the cores with balsa prior to sheeting. - John.
