RE: Inverted 2-stroke with Perry Pump problems
The problem with perry pumps is that fuel is delivered to the carb whenever they see pumping pulses or vibration. The engine to be strated is not running yet, and will flood very easily. Prime the engine with plug out! and spin shortly. Pinch the fuel line to the carb to prevent more fuel from entering the engine, put the plug back in and start. Remove the line pinch as soon as engine fires up.
