RE: JR Quirky Failsafe tests........
I have some questions to clarify some items for the guys doing some testing.
1) Are the uncommanded elevator, and other inputs due to the fact that the servo and channel programming in the interfering TX is different than the original TX programming and this is the signal being read by the RX? Or, is it a byproduct of the failsafe chacteristics?
2) Does it happen with any JR RX used, be it ZPCM, SPCM, synthesized SPCM, or PPM?
4) Does it occur exactly the same with the Weatronics and Multiplex IPD RXs, as they handle failsafe in a different maaner?
5) Is it exclusive to the JR 10X and 9303 TXs and new SPCM RXs? The previous series JR 10, 10S, 10SX, and 10SXII had the ability to program failsafe time settings. Was that feature only available when used with the ZPCM RX?
6) Is it possible to "reprogram" the JR 10X and 9303 TX to correct this occurrence if JR finds a problem?
7) Has anybody been able to recreate a similar reaction using either the Spetrum systems, the JR/Spektrum module updates, or the XPS modules? Meaning, is it a PPM /PCM issue and not a PPM/2.4 problem?
Thanks.
