RE: Nitro Rustler Shock setup Question
you extended the arms and didn't go with stronger springs[&:] First thing is get used to it hitting when you drop it. Don't mean ^&*$% you need to start with more or heavier springs just to start. Put as heavy a spring on the back till your truck starts pushing the front end in corners then work back from there[&o]
