RCU Forums - View Single Post - Twist 40 3D with Saito engine cut out problem
Old 05-26-2007 | 12:59 AM
DNAer
Default RE: Twist 40 3D with Saito engine cut out problem
After taking the whole front of the plane apart I found that the vent tube inside the tank had turned 90 degrees and was no longer pointing towards the top of the tank but to the side of the tank. I could find no other issues with the setup. Could this be the culprit?
