RE: Official T-rex 450 XL SE Thread
Tracking can be a pain and sometimes its easy. I try the high one down then the low one up. You want to be carefull not to add to your normal pitch curve to much by adjusting the tracking. so I might end up were I only need a half turn I may end up having to give one two halfs down and one a half up or some combinatin instead of just the half turn it needed. if you don't have the nice red and blue or green tape you can use clear and just put a little regulare white paper strip under it on one blade and just clear tape on the other blade for balance, then I remove it after they are tracked and reverify. once tracked this way they always stay tracked but I check anyway.
JD
JD
