Kris, if you get what he is saying you will know that 70% is 40% in HH mode, LOL. 50 is 0, for every % you move from 50% setting you double it for the actual setting.
JD
ORIGINAL: corona007
Kris,
If your using the s9650 digital servo set the delay for zero. Thats for mostly analog servos. For instance say your doing a pirro and stop and your heli keeps turning thats where you use the delay. Does your dx6 have idle up switch? If so set your gyro for starters normal 80% idle 1 70% and idle 20% respectivly this is 60% in normal mode. Once you drop below 51% it goes out of avcs mode and enters normal mode. I use normal mode for hoovering idle up 1 for FF and acro and idle 2 for setting my neutral trim of the fins and autorotaion. It's kinda hard to explain, I would have to draw a sketch to explain it properly. If you dont have tape for trimming blades, Try a magic marker. No tape no fuss I just wipe it off after im done........Hope that helps.
