RCU Forums - View Single Post - Help with Mantis 20 or Echo 21.2
Old 05-26-2007 | 08:24 AM
kwmorris
Default RE: Help with Mantis 20 or Echo 21.2
Okay I started my conversion of my echo 21.2cc engine. I decided to convert it to a gas/glow engine I cut away most of the unused aluminum on the engine. I have a few questions. On the side of the crankshaft, where the coil used to be (picture 1 sided with the nut and picture 2) can I cut this off so the motor mount won't stick out so far? And the other side (picture 3) is the output side of the crankshaft, it has a hex head screw will this work to hold a prop on and how would I make a prop adapter? Where would be the best place to get a prop adapter, glow plug adapter, muffler and motor mount for this engine? Let me know what you think so far.
Kevin
ID:	691550   Click image for larger version
ID:	691551   Click image for larger version
ID:	691552   Click image for larger version
ID:	691553   Click image for larger version
