RCU Forums - View Single Post - Official HPI Hellfire Thread
Old 05-27-2007 | 10:47 AM
  #890
j-boy
Default RE: Official HPI Hellfire Thread
Hey ya'all! I have decided that one of my problems is simply slop in the steering syustem. []
I use a nomadio react and I had the endpoints set so that my steering servo never try'ed to push farther than the steering knuckles would allow. That's what the endpoint adjustments are for right? The problem though, was that you could pull the wheels back toward center a little if the endpoints weren't set past there maximum travel point. Setting the endpoints past the max travel allowed the servo to hold the wheels in position much better. So problem solved right? WRONG!!! Next thing I know I toasted a steering servo! So I guess I'm gonna grind a little off the hub carriers or steering knuckles to allow for a longer travel and see if that helps any. My hope is that if I can get a tighter endpoint on my servo, that the slop won't matter so much. I allways like to remind everybody that I'm basically a newb so take this advice at your own risk!!
