RE: Separates Set Up Help !
OK, but did you try the speed control without the gyro in the rudder channel? You would then see if there's some weird programming in that channel. I have a 9C so I can't help you with your DX6, but the output of the rudder channel is pretty straight forward, normally?
Good luck
Georges
