Metal - what plane are you talking about? A simple 40 sized 4 lbs profile or a 107" 100 cc plane? One thing you want to make sure if you are on the lower end is to ensure your gears do not strip ... not just sufficient torque but also the safety factor.
Was Kyle using only HS 645s on his Funtana 90?
