RE: SPE 26 Help
ez-e,
Set both needles at 2 1/4 turns open. Fire your engine up and with a tach lean the top end until peak rpm and back off 1/8 turn. Move to the low needle and lean 1/8 at a time until you loose a good transition and back of 1/8 turn. Go back to the high end and reset.
