RCU Forums - View Single Post - D4 Diablo engine 'starter' problem
Old 05-28-2007 | 02:50 PM
hpi apollo's Avatar
hpi apollo
Default RE: D4 Diablo engine 'starter' problem
you should probably take apart the brake assembly and compare it to the manual, check and see if things are worn down, and then when you put it back together, adjust the linkage so at neutral its free to roll (same with 100% throttle) and that full brake it grabs really hard
