RE: Protech Tojeiro-90 build. The last one?
Wagen017,
Good talking to you again. When I installed the adjusters I flew the airplane and trimmed it with the adjusters until I no aileron trim in it at all. The one thing that I did not do is the lateral balance. Once I had the trim correct I used incedence metes and set the wings to 1/4 degree of positive with the stab set a zero. My CG is at 165 mm from the leading edge and with this set up the Tojeiro uses almost no down elevator for inverted flight. The half reverse cuban 8 is simple now, you can set the 45 degree up line and she tracks real nice. Landings are slow with a slite nose high atitude.
Good luck
Larry
