That is the classic Tamiya issue, the DMD Units are over priced, at least from my point of view.
The model's construction cost is at:
http://web.mac.com/ksoc/iWeb/Special...zer%20III.html
Other DMD cost effective options:
1. Some have found good deals on Tiger DMD units on ebay.
2. Some long time modelers have bought a new Tiger kit, kept the DMD Units and other rc parts and resold the kit on ebay as a static kit.
3. Plug and play Tamiya infrared PZ III; share your DMD Tiger I or King Tiger Units with your PZIII.
Your PZIII can share the DMD Units and the transmitter with your Tamiya Tiger I or King Tiger, since you can only drive one tank at a time on battle days, why not.
Inside the PZ III, change the turret rotation motor wire leads to a Tamiya DMD connector. Now all you have to do is install the 2 DMDs (buy a second receiver, matching crystal and TBU set), plug in the battery to a Y connector, plug in the turret rotation motor, plug in the TBU and LED Emitter, place the DMD switch and the model is ready to go.
Takes less than a couple of minutes to install and reinstall after you have gone though the initial build (see this web site for build approaches:
http://web.mac.com/ksoc/iWeb/S.C.A.T...0Projects.html ).
