RCU Forums - View Single Post - How Do I Wire an Ignition Kill on a DA50?
Old 05-28-2007 | 05:24 PM
Antique's Avatar
Antique
Default RE: How Do I Wire an Ignition Kill on a DA50?
There are only 2 wires used in the DA engine.The third is not connected to anything...It WILL stop if you cut one, but the ignition will still be connected to the battery...There is no other way, use a switch in the power line....
