RCU Forums - View Single Post - 3d setup servo question
Old 05-28-2007 | 06:30 PM
RVM
Default RE: 3d setup servo question
You probably won't need 625s on the ailerons for the two planes you are interested in. 225s should be quite good and run you a bit less money and a bit less weight.
The 625 on the rudder is good, but the 5245 may be a bit better just because it has better holding power due to it being digital.
I'm thinking 4x 5245s for simplicity - one on each aileron, one on each elevator and one on the rudder. HS 65HB or HS81 should be perfect for the throttle. 225s on the ailerons would be good if you want to save a few bucks.
Just my 2 cents.
Good luck and let us know which plane you decide on as well as how you plan on equipping it!
ORIGINAL: MetallicaJunkie
sorry guys, i forgot to mention what size the airplane will be... well i dont have it yet, but it will probably be a 40 -60 size airplane
i was thinking hitec 5245 for each elevator halve, and HS 625s for the rudder and each aileron
thanks for your replies guys
