RCU Forums - View Single Post - How do you do a Mid tank Configuration?
Old 05-28-2007 | 08:03 PM
mortimersnerd
Default RE: How do you do a Mid tank Configuration?
Do a search for the Ofna throttle mod. It will easily tell you everything you need to know. If you already have FLM chassis plates, just order up the servo plate and you should be set. It comes with an aluminum cross bar that supports the servo saver cams.
