RE: Hovering CPP?
Vortex05, Thanks so much for your response. Being new to the helicopter world can be a handful. I had never heard of your response on the throttle trim,
-Once the reciever arms and goes green, move the trim back up to mid-point just below the mid-point before you hear the blades try to spin.
This will give you the full range of throttle.
I had never heard or read this anywhere, is this a normal set up for the CPP? And if you don't do this are you not able to get full throttle range?
Also, again being new to all this trying to set up the pitch seems a little overwhelming in the fact that I don't want to screw anything up. In one instance, it hovers now but on the second hand I think it can hover better. I will do a lot of reading and digesting of information and try to get the pitch checked and set.
Any other suggestions would be greatly appreciated. I have the G90 gyro set and the tail is rock sold.
Thanks Again.
Hover On!
