ORIGINAL: crashcrash
Well...I'm on a real roll here. Cant make the Pro fly. My Corsair, took it out this am and it was flying REAL good. Then...no control. Ended up nose in from 60ft up...totally obliterated. The supplied quick connector on the elevator servo supplied with the kit FAILED. One good note...the whole plane was a pile in one spot and the battery ended up 4ft away. The AR6000 don't have a scratch on it but the servos took a major hit and the plane is a total (the propeller didn't break!!!). JHC...maybe I just need to get the heck out of R/C all together...I have NO luck with this "sport". The corsair had issues from day one that are based on overall quality of the kit (stripped the drive gear first day due to improper mounting at the factory, and went to a different drive gear/motor combo). To make the plane right after you buy it requires MAJOR mods and replacing the supplied hardware with good quality DuBro stuff.
Sooooo...cant fly squat, I will work on the yard (yeah...OK). Cutting tree branches that are too low, my buddie is running the chainsaw, I'm holding the ladder (see broken hand VS vibration). Branch is about 3-1/2" diameter...falls and hits me in the right rear torso...knocks the wind out of me NOW. I shake it off...continue working on the yard. Later...using the tractor to re-locate concrete to fill a nasty hole....the 1" pin comes out of the hyd cylinder and oil shoots every where...didn't find the pin and that's a must have...gotta find it tomorrow. Anyone need some of this rotten luck? I'm willing to share! Everything I touch turns to poo lately. NOBODY can have this bad of luck and live to tell about it. I'm waiting for a grabber or to get hit by a stray bullet, or get creamed by a car....oh wait...I'm not that lucky.
Maybe you need some of Ricks good luck for a while... it looks like it left him and is looking for a new home. If voting, I would vote you get it... You've had crappy luck as of late. Maybe you should take a holiday and just leave everything that you normally do alone
The other side of the coin is, you've had so much bad luck, you're about due for a good luck streak!
