RCU Forums - View Single Post - balancing
Thread: balancing
Old 08-22-2002 | 04:53 PM
digger.10
Default balancing
You should do the primary balancing with the tank empty, as you will want the plane to remain flyable when the fuel supply is exhausted. This means you may be slightly nose-heavy with a full tank; this should cause far fewer problems then ending up tail-heavy.
