RE: Zlin 526
I have a virus in my computer and it is called AOL. Lord how I hate it. Long story about why I'm stuck with it for now....oh well. Just tried to up load responses to you guys and -poof- all went dark.
Jeff and Gene, thanks for the info and Gene, I get everything in good order, thank you very much.
Ray,
I was all set to order Robart 95 deg retracts and then discovered that Century Jet Models has a set specifically designed for this model. They look good, but cost $375 and I am not sure if that is with or without all the valving etc. Will check it out, but will most likely get the Robarts.
The .91 fits nicely in the cowl, BTW the workmanship on the cowl is very good, just will have to wrestle with the muffler exit.
Thanks again guys,
Bish
