RCU Forums - View Single Post - effect of prop pitch on efficiency
Old 05-29-2007 | 07:52 PM
combatpigg's Avatar
combatpigg
Default RE: effect of prop pitch on efficiency
Depends on the kind of efficiency you are after. If you are trying to get the most flying time, you will prop it one way, the most vertical or the most speed..you will use other props that meet those goals. There is no one size fits all prop........the best prop for whatever you are after will be the one that you haven't tried yet.
