I did it! the lightest 56cc engine around
Hold off on the cutting saws they are alot heavier more like the husqvarna, the piston, con rod, case, crank I mean everything is alot more robust and with it comes weight I looked at every available machine prettymuch known to man and the stihl is one of the lightest ones out there and yes they can be had quite cheaply because there is alot of them out there.
I did get it running lastnight but it had a air leak at manofold and when it was warmed up it would not start because it made the carb hot so with all the problems I had I still managed to hit it with a tach barely long enough to get 7350 on a jz zinger 22 6-10 so I just need a carb manifold for it and I will be able to get real #'s
Darin
