RCU Forums - View Single Post - axe cp thread
Old 05-29-2007 | 09:03 PM
  #983
Faststar
Default RE: axe cp thread
Update!
For anyone trying to fly the AXE CP with a 401 gyro and a brushless tail motor.
Speed controllers do make a difference.
I better also add that I am using a DX7 Tx.
After trying a couple of different speed controllers, I had no success until
I wired up the Castle Creations Phoenix 10 brushless esc.
I had lag problems with the other controllers.
This is not to say that the 240 gyro or others will need this esc to operate properly.
And Heliko if you see this I want to let you know that I had to abandon the trimmed down
tail rotor blade because it would not generate enough leverage to offset the throttle curve and torque.
I think you know what I mean.
I now have a great esc that is adjustable and I finally have the perfect tail that I have been looking for
since febuary.
By the way Heliko, I know that eventually I will want to go brushless with the main rotor motor.
Have you decided wheather or not you are satisfied with your selection?
FJ
