RCU Forums - View Single Post - Which Engine for Biplane Build
Old 05-30-2007 | 02:20 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: Which Engine for Biplane Build
Considering the significant weight of most .60-sized ball-bearing engines, you might want to consider the O.S. .65 LA. It actually out-turns the .61 FX on a lot of props, but it weighs about the same as a .46 AX. It will give you the power that you want without making the airframe impossible to balance.
