RCU Forums - View Single Post - DA 50 Running Problems
Old 05-30-2007 | 10:15 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: DA 50 Running Problems
ORIGINAL: chris monroe
I am having problems with my DA 50 and looking for help. It has been running fine for about three years with no problems. At the end of last season it began to have problems sputtering on the high end. I sent it back to DA for service and they updated several items on the engine. I just placed it in a Yak 54 with the DA tuned pipe. I was able to get the engine adjusted to a smooth idle and transition; however, when at full throttle it would not run consistently. It acted like it was too lean so I continued to richen the high end. It improved but I ended up eventually backing the high end screw completely out and it still continued to act this way. I never had any problems until now and am looking for some help. I called DA and they said it sounded like fuel draw issues; however, I am using the same 1/8 ID fule tube that I have for the past three years.
The engine was completely reconditioned by DA and this was the first time out of the box. It has a new ignition, plug, DA updates, etc. I checked the fule with a friend flying who had no problems to help narrow down the possibilities.
Any suggestions on why it would sag and then begin to surge at full throttle?
Sagging and surging at full throttle indicates a lean condition.
Read through these forums. The rumor is -- that carb is too small for the DA50 and won't pass enough fuel to actually make the engine rich on the high end. You already know this -- you've backed the high speed needle all the way out and still too lean. You've put a pipe on it and thats going to use more fuel. More power = more fuel comsumption. You'll NEVER get the carb rich enough to feed that engine with a pipe on it.
IMO it's obviously lean. But, the problem is--no amount of fussing with it will ever fix the problem.
You need to find out what carb the other guys have put on this engine as a replacement. Buy one of those and install it on your engine.
