RCU Forums - View Single Post - Great Planes Ultimate Bipe electric
Old 05-30-2007 | 12:35 PM
biplanemurphy's Avatar
biplanemurphy
Default RE: Great Planes Ultimate Bipe electric
TTSKI....thats why I stuffed an E-flite 480 into it. Massive power for pullout of hover..also extreme vertical performance!!![sm=spinnyeyes.gif]
Although so much power means careful throttle management in level flight, so as not to rip off stabs and elevators..stripping elevator servo as well.[sm=punching.gif]
Making a motor mount was easy...used the ply mount provided, and 480 mount to trace holes on some flat aluminum. then cut and drilled. Works great!!!
Hope you figure out a prop solution, Because this plane is really fun with the uplines. My buddy has the Fliton Rogue bipe with the same gear in it. We fly together starting with close together Hovers, then climb straight up untill they become the tiniest speck in the sky. Then dual flat spin all the way down. followed by anything else we can think of.
