RCU Forums - View Single Post - Substitute for Ether
Old 05-30-2007 | 02:46 PM
  #810
merugo
Default RE: Substitute for Ether
Also I run briefly on castor-olive mix. It appears to be a very good compromise. I guess this mix is really clean and has less viscosity than straight castor, but sufficient for making engine running smoothly.
I will try to measure the viscosity of this oil mixture.
As for "cheap" oils, obviously this is a quality unrelated with viscosity, better to refer the composition, if possible.
Ugo
