RCU Forums - View Single Post - Another Tamiya Leopard
Old 05-30-2007 | 03:18 PM
  #158
strv122
Default RE: Another Tamiya Leopard
The radio is listed by NAME, on page 2 of the instruction manual, along with receiver: FP-114H which is no longer made and has been replaced by 124H. Remember this kit was released in 2004, this radio is also featured in the Tamiya video of the Leopard. There are also precise drawings in both the instruction and the operator’s manual showing the Attack 4WD radio. Back in 2004 thru at least mid 2006 this was the radio/receiver featured for this kit, plus mail order firms like Tower Hobbies during the same time period sold this as the radio for this kit.
This kit was designed to be 100% compatible with this setup, if you want to use the GBS WITH NO problems; this radio along with the R124H receiver is the system to get. You can use other Futaba FM radios with this kit and as shown by the previous above post can be made to work, its the GBS that could be a problem should they decide to purchase it. There was a member a while back called Leoparddriver who had the same FM radio and could not get the GBS to function.
Read carefully, the 7CAP works with the DMD, not all PCM radios from all manufactures will work, read about the HiTEC.
Will
